From their web site:
http://www.amplifive.com/science/
I'm sorry but 1 MHz does not equal 106 Hz. This sounds completely bogus and without any scientific basis.
It may work by placebo effect, which can have real measurable benefits. If you think it works, it does (sort of).
I've seen many similar claims made for devices containing magnets.
Electrical frequency is being measured by the counting of the number of occurrences of a repeating current flow per second. This unit is called Hertz (Hz) and for convenience it is defined in multiplying units like: KHz, MHz, GHz and THz. When referring to living organisms the proper frequency measuring unit is MHz Megahertz which equals to 106 Hz.
It has also been discovered that the general human healthy frequency is within the range of 62-72 Hz and when it drops to lower levels it enables the appearance of variety of diseases. When the frequency drops, the immune system is compromised. For example at the level of 58 Hz, diseases like cold and flu were more likely to appear. On much lower levels (42 Hz) Cancer appeared in humans. Scientists started exploring other elements besides sheer frequency i.e. the Hz measurement. With many diseases the waveform and wavelength sweep had made a tremendous difference in the overall impact. Pathogens have a low frequency. Pollutants - both particulate and radiation (EMF) - lower a healthy frequency. Processed and canned food having a frequency of zero can greatly diminish a person's own frequency.
