I have been out riding the bike since the weather had eased up (it is 47 degrees out).
Honestly, this thing is WAAYYYY too powerful. I mean, Good Lord, the torque is freaking uncontrollable. 45 mph gearing on this system is way too low for the torque it puts out. It needs to be geared for 60mph,at least, (I think) in order to tame the explosive hit. I have been messing with the CA and that has helped alot. But, I think I still have some programming to do. The torque comes on INSANELY hard! With all my weight on the bars, it just jumps and wheelies violently. Now, with the amp switch set to low (6kw), it is nice and tame and smooth. But, on high it is freakish. I cannot get it to pull more than 510 amps. It just launches HARD at 500 amps. The system is capable of well over 800 amps. I want to gear it up and see what happens. I think the CA struggles to regulate smoothly from innitial throttle input on a system with this much power. It does regulate, but, there is a harshness to the low speed throttle input that is difficult to manage. I will continue making program changes to the CA in an effort to tame it. Much of this will probably dampen out with taller gearing. Also, I think taller gearing will increase efficiency as well. Right now it runs about 50wh per mile at 25mph cruising. That number should be more like 35 to 40wh per mile. With taller gearing, the efficiency may improve due to less motor RPM per MPH of running.
Oh, one other point. If ridden like a madman, launching out of every corner, wheely-ing all the time and running full throttle everywhere, the WH per mile is 85. That may sound high. But, for a system with this much power, that is actually really low. This bike is definately setup for hard running. It is running modestly that I need to work on now.
The system is very mellow in sound and pleasing to the ear. Admittedly, I like the high pitch sound of the 5mm pitch belt. But, this is much more pleasing to listen to on extended rides.
Matt
