TristanP
To be honest I'm totally not impressed by this project so far. Actually I thought all the unproven claims and buzz words were a bit annoying by times.
First of all do "solderless" solutions for batteries already exist. So do we have spring loaded battery holders and battery clips. (A lot of them even stackable.) Also if you have a high enough demand you may order your cells with screw terminals, from the factory, instead of button or flat top. No rocket science and probably not protected by obscurity or patents at all.
The second thing is that connections need to be reliable. Previous mentioned options do have their applications, where batteries need to be serviceable, but I would say they are not as reliable as joining two metals by fusion. Spot welding is also the cheapest option, even if you decide not to buy a spot welder and let a 3rd party take care of it.
It would have been helpful if zzoing took at the different approaches of building battery packs, before jumping to conclusions in regards to labour time and costs. Two fine examples of total different approaches of building battery packs are the Bosch power packs and the Bionx packs.
Bosch power packs are completely over-engineered, especially compared to the batteries for their tools, but really nice built. The production of these power packs cover a few simple steps, which are not labour intensive at all. The materials used are nicely engineered, can be ordered in different quantities all around the world and don't use a lot of raw material, being it metal or plastic. Cells are connected with only one spot weld for each of them.
The approach of the Bionx battery packs is a little bit more straightforward. 10 cells (5x2) are glued together and spot welded in series; 4 of these series are paralleled by glueing those together and connecting them by thick copper wire. These packs are wrapped in PVC and placed in a cheap plastic case with the BMS. (Probably with some added foam in the later models to secure the pack in place in the casing.)
I don't want to judge zzoing's work so far, but I'm really not convinced at all it will lead to something viable. Quite the opposite actually. I think there's an issue _how_ the showed prototype relies on screws to make good contacts. especially if you take tolerances in cell dimensions into account. Even if I'm wrong here: the most important aspect is not covered correctly and that's the end price of this niche product. (Don't forget the costs of raw materials here, which will be totally over the top for the cell holders alone.) Dave from EEVBlog made a very nice vlog concerning the pricing of products.
[youtube]UwrkfHadeQQ[/youtube]
