iangreenhalgh
- Joined
- Dec 24, 2015
- Messages
- 200
Hi folks
I have a pair of 48v battery packs I made using laptop grade sells in a 12s10p config.
My bike uses a pair of 1000w ebay hub motor kits.
The controllers with both motors are identical but I don't know who made them. They are marked 42v LVC.
I am worried about the amount of sag I am seeing on my watt meter, the controllers, despite being marked 28A actually pull 30-31A on full load.
Because these are laptop grade cells, adding a string to make the packs 13S seems a good idea - the BMS I have on each pack (identical BMS boards) are 13S capable - the end wire is simply not connected in the current 12S setup.
I have some spare cells to modify the packs to 13S, but I'm wondering, will the controller handle the higher voltage?
Also, are there any other potential issues I;m overlooking?
