fitek
Working on bike #2 using standard bicycle chain (1/2" pitch), the No.25 chain was a pain in the butt on bike #1. I'd like to just attach the motor (which has an 8mm D shaft) to the rear wheel sprocket. This is a single speed children's bike and the rider's pedaling does not connect to the wheel. The rider connects to a 36v DC motor that will be used as a generator. For that, since the forces aren't too great, I just brazed a bicycle sprocket onto the no.35 sprocket that came attached to the motor.
I could switch the whole thing to #25 chain, but I'm rather tired of the stuff. I'm not sure what would happen if I disassemble the rear wheel. I imagine the rear sprocket on a single speed wheel with an internal brake is not as easily swapped out as on a wheel designed for multiple gears.
Haven't found anything so far, so I may just get one machined.
Edit: I seem to have made a confusing post, not using 8mm chain but 8mm d-shaft motors and standard bicycle chain
