Arduino Noobe Needs help.
Boyntonstu
๐Ÿšดโ€โ™‚๏ธ Mega poster
Boynton Beach, Florida
This is all new to me:
I have a Hobbyking 150A 1/8 scale controller and a 213 KV 59mm Turnigy motor and I don't want to burn anything up.
I have this nano Arduino:
This 3 wire Throttle Thumb control:
Also:: Hobbywing 3A Switch Mode UBEC 5V 6V Max 5A Lowest RF Noise Brand New US
And this Sketch code given to me by a friend who says that it is on/off only and not variable.
#include <Servo.h>
Servo ESC;
int Button;
int Speed = 1500;
void setup()
ESC.attach(9);
pinMode(13, OUTPUT);
pinMode(A5, INPUT);
digitalWrite(A5, HIGH);
void loop()
delay(25);
Button = digitalRead(A5);
if(Button == LOW)
digitalWrite(13, HIGH);
Speed = 2000;
else if(Button == HIGH)
digitalWrite(13, LOW);
Speed = 1500;
ESC.writeMicroseconds(Speed);
Wiring advice:
Arduino pin
5V - Ubec + Throttle red
GND - Ubec + throttle white + battery ground
9 - ESC signal
A5 - Throttle green
First: Please double check the wiring advice.
Second: Please advise modification to Arduino sketch to enable speed control.
I really would appreciate your help.
Do you have a link to that motor? any pictures of it connected to your bike?
Also what voltage is your battery? What type of battery? Lithium or lead? Link to battery?
Do you have any idea on how you are going to use the motor to drive your bike?
I just saw the price of that motor and the esc. Have you already purchased them? You can get a better, ebike specific, motor and controller for less.
Interesting: What do you recommend for a 6S 20+ MPH direct can friction combo?
BTW My 12 A 6S battery cost is almost zero.
TECH_GEEK10 said:
This is you taking this video I assume?
Yes.
Since the video, I upside downed the pivot and it jumps in the correct direction.
Something is wrong with the motor and or ESC that is limiting the output.
I have a bunch of concerns that I am seeing in that video, and would like to go over a bunch of stuff that a forum really is not suited for. Do you have a skype account? I don't need to use the camera feature of skype just the instant messaging part.
Sure what is your skype name?
complete solution using a arduino
throttle control
http://endless-sphere.com/forums/viewtopic.php?f=2&t=61004
watt meter
http://endless-sphere.com/forums/viewtopic.php?f=2&t=61407
throttle control
watt meter
Thanks, but I am not knowledgeable to choose from all the solutions posted on the thread.
I need to 1> Verify the wiring.
2> Modify the code to allow speed control.
Thanks
The second lot of code in the first link is what you need.. you un rem all the rc esc parts and rem all the ebike contoller parts. The code does a lot more that just the speed contol if you want to wire the current sensor but its not needed for basic speed control.
A minimalist code for speed control and a wiring diagram to the Arduino would be greatly appreciated.
I have stripped just the speed control out,, but I have not tested it .. but it looks ok..
D3 on the nano is the output to the esc
A7 is the input from the throttle
the grounds joint together, ( throttle,esc,nano ) and all the +5v join together ( throttle,esc,nano ) .
the nano needs to be powered from +5v
Code:
// set servo for 1.1ms min - 1.8ms max ( or auto range )
 * A7 (throttle input)
 * D3 (control) (throttle output) , RC filter is required on output for e-bike controller,, no rc filter for rc esc
// #include <Servo.h>
const int Throttle_Input_pin = 7;  // Throttle input A7
const int Throttle_Output_pin = 3;  //Throttle output D3..
const int Set_Min_Servo = 1000;  // esc start with this as min throttle  // (rc esc)
const int Set_Max_Servo = 1800;  // esc end with this as max throttle  // (rc esc)
int Servo_time = 1000;   // (rc esc)
int Throttle_Value=0;
int Throttle_Pulse=0;
int Set_Throt_Min = 55; // this needs to be the min value to remove dead band from throttle output , around 55
int Set_Throt_Max = 180; // this needs to be the max value to achive full throttle without cutting out , around 180
int Cal_Throt_Min = 176; // this needs to be set to the real value of the throttle when fully closed;
int Cal_Throt_Max = 842; // this needs to be set to the real value of the throttle when fully open;
void setup()
{ //--- initialize serial communication at 9600 bits per second:
Serial.begin(9600);
analogWrite(Throttle_Output_pin,0);  // (e-bike)
Servo_Pulse.attach(6);      // Attach Servo_Pulse to pin 3  //  (rc esc)
Servo_Pulse.writeMicroseconds(Servo_time);  //  (rc esc)
delay(1000);
void loop()
Throttle_Value = analogRead(Throttle_Input_pin);
Throttle_Pulse = constrain(map(Throttle_Value,Cal_Throt_Min,Cal_Throt_Max,0,1023),0,1023); // set range on throttle
Servo_time = map(Throttle_Pulse,0,1023,Set_Min_Servo,Set_Max_Servo); // scale output
Servo_Pulse.writeMicroseconds(Servo_time); //output servo signal to controller
