Are these capable of 40A charging rate??
ebike11
far away
https://hobbyking.com/en_us/turnigy-high-capacity-battery-20000mah-6s-12c-drone-lipo-pack-xt90.html?queryID=82e067fdf0390db0dbdf000d8d28360b&objectID=78412&indexName=hbk_live_products_analytics&___store=en_us
These cells are rated 2C in the specs, so Im assuming 40A max. charging rate? :shock:
There is a 20A charger that Im looking at but wanna make sure the lipos can handle 20A safely and easily
Yes.
168 wH/ kg and 2050? Watts pef kilogram.
Does it run on 220VAC ? I was having to reset the breaker in panel when charging at higher currents using a 110VAC supply, but the circuit was barely enough for the 1500W supply, so no issues in the garage where the circuits are beefier.
This was using an iCharger S6, 40A charger.
Ah yes...im using 220V
