hi..
my regular current meter is in the shop, so i thought i'd use this: http://www.dfrobot.com/index.php?route=product/product&path=70&product_id=454#.UE5Nr43iYRB , but since my battery is 48 volts, i used a voltage divider (20000/20000) , so while the actuall voltage is around 53, when i connect the divider, my regular lab voltage/current meter shows 26 volts, however when i connect the led voltage meter, it shows 4.4, suspiciously this is just below it's range of 4.5-30 volts. so i guess it means something. i've tried different wires, i also have 2 led voltage meters and i get the same result.
