Geebee
If you tell them it is 200w rated there is no speed limit, if you tell them its 250w 25 kph limit.
So pick your wattage carefully
newb said:Responding to my own question. My gut says that they were doing us a favor by not asking, that if they had and then got an answer beyond the legal limits they would have had to react. Bad hypothesis?
Architectonic said:newb said:Responding to my own question. My gut says that they were doing us a favor by not asking, that if they had and then got an answer beyond the legal limits they would have had to react. Bad hypothesis?
The law itself is badly designed and never tested in court, they don't have anything easy to write in the expiation notice book?
They are doing themselves a favor, though they will no doubt try something if you are riding dangerously.
Architectonic said:I ride past cops at 40kph all the time, they don't even seem to turn their heads half the time.
winkinatcha said:Article for LiPo fire...
Impressed by lack of "ermigerd! Battery SPLOSION!"
http://www.theage.com.au/victoria/exploding-battery-leaves-150k-damage-bill-20130709-2pndq.html
Joe
Rules for motorised bicycles
There are 2 types of legal motorised bicycle. For the first type, the electric motor must not be capable of generating more than 200 watts of power. For the second type, know as a 'pedalec', the vehicle must comply with the European Standard for Power Assisted Pedal Cycles (EN15194). The vehicle must have a permanent marking on it that shows it complies with the standard. A compliant pedalec can have up to 250 watts of power. But the motor cuts out at 25km/h and the pedals must be used to keep the motor operating. It is illegal to ride a bicycle on roads or road-related areas (such as paths) if the bicycle has an internal combustion engine (for example, a petrol or diesel motor) attached.
Motorised bicycles are required to adhere to the same road rules as bicycles and have the same rights and responsibilities. Motorised bicycles are exempt from registration and compulsory third party insurance.
A two-wheeled vehicle with an internal combustion engine, or an electric motor capable of generating over 200 watts, must comply with the Australian Design Rules* requirements for a motorbike if it is to be ridden on roads or road-related areas.
When riding a motorised bicycle you must:
wear an approved bicycle helmet securely fitted and fastened.
The motorised bicycle must have:
a bell or horn
at least 1 effective brake.
When riding at night you must display:
a white light at the front, visible for 200m
a red light at the back, visible for 200m
a red reflector at the back, visible for 50m.
You can ride a motorised bicycle on all roads and paths, except where bicycles are specifically excluded.
You do not need to have a driver licence to ride a motorised bicycle.
Architectonic said:Bell is essential if you ride on shared-use paths. So are AJ's 200w stickers. :wink:
I don't have reflectors though, I figure lights are enough.
