BAFANG BATTERY CONNECTION HELP
eBiker2017
Hi there
Newbie here seeking some advice. I have the Bafang BBS02 MD kit and also a Sun ebike battery. I am new to this and am not sure about the power connection. The motor has 5mm bullet connections and the battery appears to have an IEC femal for the discharge. Where would I get or how would I make a suitable connector to get this working?
Any help would be greatly appreciated.
Thanks
eBiker2017 said:
Hi there
Thanks
Pictures would help, but googling ebike connectors will get all sorts of good info. Google and check images.
https://www.electricbike.com/ebike-connectors/
eBiker2017 said:
Hi there
Thanks
Suggest you either:
1. replace the battery connectors with bullets that match those of the motor, or...
2. replace both sets of connectors with a set of the yellow AMASS XT90 connectors.
The former are cheap and long lasting. The latter are a little more expensive but very secure and have the advantage of flash suppression when used correctly. Both available on eBay or from EM3ev or elsewhere.
Sam.
