Hello guys.
I'm about to buy the BBSHD 1000w motor for a project that could take up to a few months to be able to afford all the parts.
The deal I've come across is on aliexpress (im not sure if linking to aliexpress is allowed but will link anyway)
the battery says its a 52v 20Ah battery. Here is the link
I also understand this should see me at speeds of around 28-33mph with the default bfang controller maxed out.
According to e bike battery calculator Im looking at a range of 48-52 miles with minimal peddling.
I've also seen an after market mod called "phase runner" that can be used to really beef up the 1000w motor but im unsure as to what improvments this will bring and if a bigger battery would be needed.
Im thinking a 52v/40Ah Rr even 50Ah would actually be the better idea for a battery - but would the phase runner/1000w bfang handle a bigger battery like that even jumping to say 72v/40Ah?
Essentially I'm looking to get the most out of the BFANG 1000w in theory and this is the info i came up with.
Outside of that - a 3000w hub motor I've seen some guys clocking in at 48mph - With a 60v/24.5Ah battery, but they said they wish they got a a larger capacity battery. Imalso aware anything above a 3000w hub on a mountain bike frame is not advised, as there is not enough weight pushing the bike down for stopping traction.
For ease of buidling the BFANG has this area won IMO and its much easier to repair a rear flat.
thanks.
thanks.
