Bafang bbshd 48v 1000w
acelec
I had an issue with my display not showing the correct charge level on my display, apparently it's because bafang controller seems to only recognise 52v batteries and mine is 48v.
I followed a you tube video from golden motor, simple enough, and sorted the issue.
However when I connect the cable to the motor using the app I get 30h error and the only way to clear it is to flash it again.
Anyone know how I can still use the app without the error code appearing or different firmare I can use and still get the correct info on my display minus the error code.
