spinningmagnets
100 TW
Page 2, Bafang web-catalog http://szbaf.com/product.asp?page=2&pid=1&cid=0&keywords=
Green Bike Kit http://www.greenbikekit.com/index.php/electric-motor/bldc-bpm-500w-36v.html
E Life Bike http://www.elifebike.com/peng/pic.asp?ModID=PicS224&TypID=S220062
BMS-Battery http://www.bmsbattery.com/90-bafang-motor
EV-Assemble http://www.evassemble.com/index.php?main_page=index&cPath=17_4&zenid=npd1b29m06m7ovvsktb9j7dle7
Bafang 500W-BPM also available from ES member Keywin / ecrazyman@gmail.com
http://bruceteakle.blogspot.com/p/blog-page_8.html
Crossbreak and Miles have calculated that the Bafangs "might" run well up to 2,000-RPMs at the motor (5:1 reduction to the output shell, so 2,000 motor-RPMs = 400 wheel-RPMs), and any RPMs above that: efficiencies and waste-heat both slowly curve to the bad side...
http://endless-sphere.com/forums/viewtopic.php?f=3&t=35323&start=100#p608467
Here is a breakdown of the BPM-II, showing the minor differences.
http://endless-sphere.com/forums/viewtopic.php?f=28&t=45245&start=600#p768925
A short video of "fullthrottle" opening up his BPM to clean, re-grease, and replace the freewheel...
http://endless-sphere.com/forums/viewtopic.php?f=6&t=15567&start=25#p590956
Jeremy Harris' and Wurlys' acquired data on Bafang code#/turn-counts
http://endless-sphere.com/forums/viewtopic.php?f=2&t=43106
http://endless-sphere.com/forums/viewtopic.php?f=3&t=35323#p515152
This drawing is reported to be a BPM
http://endless-sphere.com/forums/viewtopic.php?f=3&t=12582&start=15#p207898
Specs per ES member full-throttle: http://endless-sphere.com/forums/viewtopic.php?f=28&t=45245&start=450#p703912
The motor pictured below was purchased from Green Bike Kit in April of 2013, and may vary slightly from older Bafang-BPM versions. Here is a link with pics of a BPM from 2012 which show some of the internal differences: http://endless-sphere.com/forums/viewtopic.php?f=2&t=35204#p513278
Wooden stand central hole is 80mm diameter, the cord slot is 18mm wide
The distance between square sides when the stand is flipped over is 5-1/4 inch / 133mm
Firstly, the two BPM models [from BMS-Battery] and the new CST cassette-hub model are all rated at 36V. The coding applies to a 36V input and all the values I will be giving you are in unloaded conditions. Let's begin with a code-16 motor and work our way to the code-8 motor.
Code_____RPM
16_______192
15_______205
14_______215
13_______230
12_______250
11_______280
10_______300
_9_______335
_8_______378. mind you, all of these specifications are directly from the engineers of Bafang.
BPM 500W Code-9
Phase impedance 70mOhm
Phase inductance 275uH
9 turns x 10 strands of d0.56mm (23-AWG)
34 lams 0.50mm
18 teeth: 17mm wide x 10mm deep x 14mm high
Stator diameter 130mm
Air gap 0.50mm
Magnets 8 pairs 18mm wide/deep x 26mm long (along the rim) 2.5mm thick
Flux ring 6mm thick
