RustyKipper
Hey Guys,
I’m currently nearing fitting my new Bafang CST and S12S controller, just finishing the carbon composite battery box and saving up for the remainder of the 15Ah Headways.
So sorry if this question has been asked before but here goes.
I know the controller will function without the LCD display by linking the appropriate wires and indeed have had the motor and controller running happily on the bench. I believe if the LCD-3 controller is not fitted the controller will default to power level 2 (out of 5 levels). I haven’t been able to ascertain if this is only when using the pedal sensor or if this effects throttle also.
I don’t want to fit an LCD as I want the bike to be as stealthy as possible and it would be just something else to be shaken to pieces on my daily commute.
The idea is to use the 500W rear Bafang as an out of town boost for hill climbing, around town I am quite happy with the 250W SWXK working from the crank sensor, even with this modest power level I have fitted a switch under the saddle to switch out the pedal sensor so some of the trickier manoeuvres can be carried out on part throttle. The 500W motor will use throttle only.... I think realistically I might just end up with the rear cst on both crank sensor and throttle ultimately but riding around town and cycle lanes on 250W kind of gives me a clear conscience.
So the question is without the LCD can I use full power (the case of the S12S shows max current being 30A) or am I stuck with the lower default power. If so has anyone tried communicating with the S12S with an Arduino or similar, it would be physically very easy to construct a simple dongle if sense can be made of the data sent between the 2 devices, I’ve successfully hacked into GPS receivers before now to build speed and altitude sensors so this should be do-able.
I have seen a few of you chaps with very tidy and stealthy looking steeds without any obvious LCD’s fitted and what looks like CST’s and S12S’s.
