Bafang mid drive error 30 issue
Snu
🔌 New-ish
Hi All and Happy New Year for Friday
I have an issue with a 36v 500w Bafang mid drive motor BBS02, when you power on everything lights up fine but after 7 seconds it shows "error 30", the throttle works fine and still has pedal assit but it goes at full speed no matter what PAS level you select.
When I stripped it down I noticed that the main controller lead from the motor was routed wrong and had been squashed, so I bought a new controller and fitted it, same issue still happens, so I disconected the throttle and fitted a new display but still the same issue, I'm now wondering if it could be the PAS sensor in the motor but I have no way of checking, has anybody else had this issue and found a resolution for it.
Forgot to mention, when I plugged the motor in to originally find the issue using the Penoff config tool it blow my USB port on the computer and the chip on the tuning lead :evil:
Many thanks in advance.
Clive
