BigRider
Hi. I have learned over time that knowing what to search for and where to search seriously reduces the level of research needed to get to the right answer. I'm willing to read, but don't know what to search for exactly.
I'm 750 lbs. Can stand and walk about 15 feet, but that's about it. I'd like to get out and do things like the zoo with my wife. I am pretty good at fabrication and electronics.
In my ideal world, think wheel chair with dual hub motors and floating front casters. I realize this won't work for a variety of reasons. I have done a few hours of preliminary searching and reading
I think two motors, with gears and chains. One per rear wheel. Big common battery. Think twist handle style controls, one per wheel.
I don't care about speed, but a bit faster than walkers would be nice.
Things I know so far:
- Hubs don't do the torque needed and have way more speed than needed
- axle sticking out that's not across the whole chair will probably snap off
- I likely want a long axle with a hub that plugs on the end and has a chain sprocket on it. Axle is stationary, hub on end rotates and is driven. Don't know the right name for this style, but that's what I've found that looks best so far.
Things I don't know
- wheel sizes that's best
- motor power and torque needed to move a solid thousand plus pounds
- how to size the battery
I can design the rest of the chair around it, but what terms do I need to research / threads that's done this. I have read some, but didn't see one just like this but my size. But I did learn some from it.
I don't plan to truly off road, but reading threads makes a good point that it needs to be able to do curbs and inclines.
I look forward to any pointers and advice. Like even "go read this particular motor thread to learn basics" is welcome. I poked around and read a few. But what is the good stuff?
Thank you .
Things I don't know
Thank you .
