Alright, dumb question, maybe. Hope this is the right forum.
This morning I ran a nominal 54 volts -- measured 59.4 at the start of the ride.
At the end of the ride -- immediately post ride -- I measured 51v.
Pulled the pack apart and found some batts with significantly (2v) lower voltages than others, some hot, some not.
The general trend seems to be that the warm ones are the ones with the higher remaining volts.
After resting all the batts for an hour I restrung in series and the pack was back up well over nominal voltage at 57 and change.
Anyway, I'd guess this means that the hot ones are
A) better batteries,
B) working harder,
C) compensating for the weaker (lazy) cool ones with low voltages?
Am I reading things right?
B) working harder,
