SportBiker
I have a few ~250w 36v (10s) battery packs.
I want to make a house bank battery for my mobile office / camping van.
I also have a panel I am planing on mounting to the roof of the van. Stats below.
The main requirement is to run an inverter.
Running things at 36v seems like it will be tricky because a buck / boost mppt charge controller would be needed, and few inverters will work from ~36v.
I am leaning to reconfiguring the batteries to ~24v but not sure if I should go with 7s or if 8s may be better. Then I could use a common buck mppt controller and there are a lot of 24v inverters.
Would 8s be gentler on the cells for a ~24v operating range? Full utilisation of cell capacity isn't necessary, I'd rather have a pack that will last longer.
Thanks for any ideas.
Panel stats:
SW-02-5004US 07-2012
SW 235 mono / Version 2.0
PERFORMANCE UNDER STANDARD TEST CONDITIONS (STC)* SW 235
PERFORMANCE AT 800 W/m2, NOCT, AM 1.5
Maximum power
Pmax
235 Wp
Maximum power
Pmax
170.9 Wp
Open circuit voltage Voc
Short circuit current Isc
*STC: 1000W/m2, 25°C, AM 1.5
THERMAL CHARACTERISTICS TC Isc
37.5 V 8.19 A
0.004 %/K -0.45 %/K
SW 235
Voc 34.0 V Isc 6.60 A
Maximum power point voltage
Vmpp
30.3 V
Vmpp
27.5 V
Maximum power point current
Impp
7.77A
Impp
6.22 A
Panel stats:
Maximum power
Pmax
235 Wp
Maximum power
Pmax
170.9 Wp
37.5 V 8.19 A
0.004 %/K -0.45 %/K
SW 235
Vmpp
30.3 V
Vmpp
27.5 V
Impp
7.77A
Impp
6.22 A
