boostjuice
http://www.chinasampo.cn/Digital-Multimeter/SM8124.htm
http://cgi.ebay.com.au/SM8124-Voltm..._Measurement_Equipment_ET?hash=item45f0ea26f9
Does any member here own or has any member used one of these meters? Google brings up no user reviews on them. I am looking for an easy, fast, reliable and inexpensive way of measuring the IR of A123 M1 cells and one of these meters seem like the cheapest and easiest option. I realise they measure internal resistance at AC @1kHz rather than DC. That shouldn't matter for cell matching as i am only chasing relative measurement, not absolute values @ DC loading.
Any thoughts on potential/experienced accuracy, precision, resolution and range of these meters?
I already have a cheap RC charger that reports battery capacity @ 1A max discharge, so all i really need to know is IR measurements to have the info needed for cell matching into parallel groups.
I'd rather not go through the hassle of manually inferring IR by Delta V, Delta I through variable loading. Also, i don't think i need to fork out the cashola for a CBAIII for what i am trying to achieve.
Should i take a gamble on one of these or just buy an RC charger with an inbuilt IR function? What sort of accuracy, precision, resolution and range do the majority of these high end RC chargers feature? I don't really need a high end RC charger as i will be running a Goodrum/Fechter BMS with the finished Battery pack, so all that is needed is a much cheaper CC/CV PSU or Pb-Acid charger.
Cheers
