serisman
I am in the process of making the switching from Lead Acid to Lithium Ion, and want to maximize the life of my new battery pack as much as possible. I would like some help in determining the best charging schedule to accomplish this.
My ebike currently has a conhismotor 48v 1000w rear kit on it. The controller has 63v capacitors, and pulls about 31A max.
With my HEAVY lead acid battery pack (~ 60lbs) I was averaging about 25 Wh/mile at approx 20 mph. I was using (4) 18Ah SLA batteries, that originally measured about 11Ah @ 10A draw (they were sitting around for about 1-2 years before I started using them). Originally, I was getting about 15 miles of range, but that dropped to about 5 miles a few weeks ago after putting about 700 miles on the bike. I re-measured the batteries and they were around 3 Ah (@ 10A). Since then, I have put them on a custom built desulfator for about a week per battery. This seems to have recovered a bunch of the capacity (haven't actually re-measured it again), but at this point I am done with SLAs for my bike.
I never really expected the SLAs to last very long. I only used them originally because they were sitting there feeling neglected and I didn't want to invest a lot of money on this hobby in case it didn't pan out. At this point, I am definitely hooked on ebiking so time for a real battery pack!
After doing a lot of research, I finally decided on and purchased the 50v 18.5Ah samsung triangle pack from cell_man:
http://em3ev.com/store/index.php?route=product/product&path=35&product_id=123
According to my calculations this should give me a range of 30-45 miles at around 20 mph, which is way more than I need most of the time. My normal commute is 15 miles round trip, but I have the opportunity to charge at both ends (and I have two chargers). I should use about 4 Ah for each half of the commute. Aside from my normal commute, I would like to be able to do a 30 mile (round trip) bike trail that I used to do under pedal power when I was in better shape. At the most, I would only do this once a week or so.
The chargers that I got from cell_man have 3 charge settings (100%, 90%, and 50%) (58.8V, 57.4V and 53.2V) (4.2V/cell, 4.1V/cell and 3.8V/cell)
http://em3ev.com/store/index.php?route=product/product&path=37&product_id=120
According to the following link, it appears the optimal charge range for longevity (while still retaining useful capacity) is 3.8 - 3.9 V/cell (37% - 63% capacity):
http://www.powerstream.com/lithuim-ion-charge-voltage.htm
So, I have a few options:
1. Charge to 90% (4.1V/cell), and re-charge (to 90%) every day (i.e. after using 8 Ah) or every other day (i.e. after using 16 Ah). Potentially charge up to 100% (4.1V/cell) immediately before going on the longer trail ride, but only re-charge to 90% afterwards.
2. Charge to 50% (3.8V/cell), and re-charge (to 50%) after each half of the commute (i.e. after using 4 Ah). Then, charge to 90% or 100% (4.1V/cell or 4.2V/cell) immediately before going on the longer trail ride, but only re-charge to 50% afterwards.
Option 1 will be (2-4x) less cycles (+), but they will be deeper cycles (- ?) and the battery will be sitting at a higher voltage for more of the time (- ?).
Option 2 will be (4x) more cycles (- ?), but they will be shallow cycles (+ ?) and the battery will be sitting at a storage voltage for most of the time (+! ?). This option will also discharge to a lower voltage than Option 1 (- ?). Worst case, I should still get 35% of the capacity by charging to 3.8V/cell which is still 6.475 Ah (more than the 4 Ah I need for each half of the commute). This should still leave 15-20% of the capacity in reserve and the cell voltage should still be above 3.7V/cell.
I am leaning towards Option 2 at this point, unless someone has a better suggestion.
Alternatively, does anyone know how to modify the voltages on the cell_man chargers? I would prefer to charge up to 3.85V/cell (~ 60% - 70% capacity) for the low end.
