safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Going Backwards in Time...
After scanning the internet a little I see that the solid electrolyte idea has been something that has been pursued as an alternative to the liquid electrolyte approach. The idea is to make longer lasting batteries this way.
Maybe the idea would (like the Vandium battery) go back to the old way and use liquid electrolytes in the LiFePO4 cells so that you could swap out the liquid at a refilling station and then wash the cathode and anode clean again.
I'm thinking that the choice of electrolyte seems to be a "free choice" and it doesn't matter that much what you use as long as the lithium metal gets transferred.
In effect this process would be to "burn lithium" (chemically) and so you would have to replace the cathode and anode over time, but that might be the way to make infinite running batteries. If you can wash out the electrolyte, replace the cathode and anode then all the rest of the battery could stay in place. (which is basically the shell and control circuitry)
If the electrolyte is 50% of the weight of the battery it's easier to drain it and replace it than to have to lift it out of the car. Replacing the cathode and anode might be as easy as changing spark plugs...
