andla said:I have 2 36 volt battery packs and they are very heavy. It feels like the weight are about 15-20 kg. I use AHR32157-M1 type and have 12 cell in each pack. How do you handle so much weight?
skeetab5780 said:so you only have 24 cells an you think thats heavy? i got 150 cells built into the triangle on my frame and i find it fairly light and easy to handle
julesa said:Number of cells doesn't mean anything. These are big cylindrical EV prototype cells, of similar size to Headways. 15-20kg seems like an awful lot though, it's hard to believe they're really that heavy.
skeetab5780 said:no the number off cells means something...not nothing. i was just pointing out that i clearly have more weight than he is talking about regardless of the cell type or quantity. i do know the type of cells he is talking about, and yes they are larger than the cells i am using, but he is talking about weight.
so 6000 cells weight the same as 1 cell apparently (since the number of cells mean nothing when calculating pack weight)
Doctorbass said:Btw.. WHERE DID YOU GET THESE CELLS? AHR32157-M1??![]()
Doc
