YoshiMoshi
🔋 Established
So let's say I want to make a custom battery pack for a power tool. I can look at what cells the manufacturer puts in their official battery packs, and see what the highest continuous discharge current is within their battery line, by analysing which cells are in their various batteries of different capacities and additions that are added over time. Let's go with 45 A. Now we can assume (hopefully) the manufacturer would not sell a battery pack whose maximum continuous discharge current is to high for their tools, due to liability reasons. Now I can go and make my own custom battery pack whose maximum continuous discharge current is much higher than 45 A. Let's say 70 A or higher, especially with the tables cells.
Now the power tool is designed with a maximum continuous discharge current in mind.
1) The insulation and garage of the wires. I've seen custom insulation, sometimes, no temperature rating, and googling the markings on it leads to nothing.
2) How much current the MOSFETs can handle
3) The maximum overall continuous discharge current of the tool that it can draw.
What is the weakest link? Can I assume the manufacturer wouldn't put in a brushless motor that can draw 70 A continuous but whose internal wiring only supports 50 A continuous? Some of these tools were made prior to tables cells, and properly were never designed to have 70 A running through it continuously. But the motor may be able to draw it.
What should one due when building a custom pack for a device whose maximum continuous discharge is unknown? Is there some risk in making a battery pack that is capable of putting out "to much" current for what the device was designed to handle, but will still draw it?
Also I've heard that the BLDC controller IC limits current. But looking through a datasheet I see nothing as far as maximum current or maximum power. Only maximum voltage. I see sections about a current comparator circuit and a sensing resistor, but no maximum current. I don't know if I'm not looking for the right thing? Some data sheets are rather large. I was expecting a maximum current or maximum power at the start of the datasheet with all the characteristics listed in tables, but there's nothing on current.
