I want to replace my Schwinn Global GS battery with a free Schwinn Tailwind battery. I want to make sure there's no problem with the match to the Global GS box on the rack (controller?) I'm seeking opinions/warnings. I can solder, but don't know much about electric. The old GS battery is 29.4V 10Ah Lithium Ion polymer. The new Tailwind is 24V 4.2Ah Lithium Ion. Am I right to assume it's ok because the replacement is less powerful? The Global rack won't accommodate the Tailwind battery and I can't get the box free without disconnecting all the wires. So, I plan to leave the box in the rack, and extend wires to the battery in a pannier. I want to leave the cylindrical pin connectors anchored securely to the battery and remove the battery via new in-line insulated connectors. That way I won't have to worry about arcing at the "butt joint" connection (spring loaded pins' contact to flat terminal surfaces on the battery), which I will leave strapped tightly together. The original failure was due to arcing of the locked-on pin to battery terminal vs. short battery life. I can still use the old battery, but there's not much left in it. I severely ration my use of it. When this replacement battery fails I'm on to a better system.. Thanks for the tips!
