Hello
I am in the process of building ebike # 2 and luckily there's no rush, as I have gotten a bit wrapped around the axle about batteries. I had been been leaning towards a Ping Battery LiFePo4 (more $$$ but good service, lots of cycles, etc) but now I'm over in the Lipo camp and here's why:
Based on what I've seen at Hobby King and what I've read here, I can build a 10Ah 44V Lipo pack for under $200 (+ harnesses and chargers and BMS and power supply and voltage alarms, but those costs would be applied over several years / multiple packs). In theory, that means I can get 3 or 4 packs for the cost of 1 good quality Ping battery. Which means that I can afford a bit more of a learning curve as I discover the quirks of Lipo and hopefully not burn down the garage. I have read the FAQ several times, I have read some interesting and educational threads here; there still seems to be some issues (ie. BMS or no BMS) but I figure I should just jump in and learn by experience, secure in the knowledge that all the good folks here at endless-sphere.com can keep me on the straight and narrow.<g>
There appears to be a bewildering assortment of Lipos available at Hobby King, but here is my choice of battery:
http://www.hobbyking.com/hobbyking/store/__18631__Turnigy_5000mAh_4S1P_14_8v_20C_hardcase_pack_USA_Warehouse_.html
6 of those configured with 3 in series = 44.4 V, and 2 parallel sets should give 10Ah, which is enough to get me to work.
Of course, then there's a custom harness and all the other goodies mentioned above but first, I would like to see if I am headed in the "right" direction with this choice of battery. It's a hardshell case, which I think should be a Good Thing. It's only 4 cells per brick, so only 4 points of failure.
I invite one and all to please tell me why this is a dumb idea, and why I should stick with something safer and more stable.
From what I've read, things can and do go wrong with LiFePo4 or LiMnO4 packs - is there that much of a difference in quality/stability?
Will I be spending all of my time fussing over these, instead of just charging and riding?
Are Lipo suitable for commuting / charging at work?
Speaking of charging - it's 2012. Does anyone make an integrated power supply/charger for Lipo batteries? Why not?
Do other lithium types require both bulk and balance charging or is it just Lipo that requires that?
Of course, I would prefer something totally stable, safe and plug-and-play, but I don't think it exists, so I might as well go with something cheap that gives a really good bang for the buck.
Thank you
dave02150
Thank you
dave02150
