Lurkin
On the way to work today, the LHS crank arm decided to be loose and it's lunched itself.
When it was installed, it was pushed on, then donked a couple of times, then the inner bolt was done up very tight to hold it on there.
A workmate has suggested pressing the replacement on with a vice or press, then appling the inner bolt with locktite.
My understanding is the supplied bolt already has loctite on it (the blue stuff) and pressing the arm on is overkill and can possibly lead to cracking the spindle.
Thoughts?
Thoughts?
