Hello,
I have a bit a weird problem. My bike tells me the battery voltage is too high (07h) - which it definately isn't. But when the controller gets a brake signal, suddenly there's no problem any more - untill I release the brake/jumper wire. I checked the battery (under load), display and cabling. The extension cable towards the display seemed a bit crushed but if I connect the display directly at the motor block, I still have the same problem, - haven't taken out the controller yet.
Motor/controller: BBS01 - ns06 v2.5 V.2.X.B.2 36V max 20A
display: C965 (v5.0)
Does anybody know right away whether the problem will be the motor or the controller - or perhaps whether it is a known issue with a firmware fix? (I can find something about an over voltage problem but it's all about 52V)
Oh, yeah: the motor symbol is blinking, which should happen when there's an error, but the outline of the battery symbol blinks too, I don't know whether this is normal.
thanks in advance for any tips
