BBS02 Full Throttle Stutter/Pulse/Cut outs
Magsy
South Wales
I’ve swapped the controller on my dads 36v BBS02 to a 48v one.
It fired up ok and I programmed it with usual settings and left it at 25a.
However the motor stutters or ‘misfires’ at full throttle. It does draw peak 1,300w but pulses violently; the display wattage bounces up and down sometimes showing 0.
If I slowly ramp it on, it does not stutter and will sustain 1,300w
I set the controller to 20a but the same happens.
I am not pedalling at all. I have added and removed the fetcher transistor throttle fix...no difference.
The battery is a brand new Hailong 14s4p 35E that I built for him. As a post production test, I had ridden it 40 miles on my BBS HD @ 25a so I’m fairly certain it’s healthy. It’s fully charged and only sags 2-3v @ 25a.
The bike and motor has a couple of thousand miles on it and was ridden to me today (healthy). I have tested the throttle with a multimeter and it’s a smooth 0.85v-4.30v
I have checked the hall sensor connector and it looked ok but I will check again.
It’s a new style controller from China.
Has anybody experienced similar and have some pointers?
Thanks
