This one is a bit long as there's some backstory. TL;DR, cheap bikes hurt you
In mid Jan 2023 I got a new ebike, sort of... it's a kit on a crappy bike, all the bike bits are Box Store quality, the build was pretty bad too... but PAS is awesome, and cruise control is awesome and with some fenders, panniers, stem spacers, grips and Brooks saddle it's a decent enough bike. I've racked up 600 miles since Jan on it. Not a lot of miles, but riding it regularly.
In early July the twist throttle stopped working, I contacted customer support, they put me in contact with local support who said it would need to be returned to the point of purchase for warranty work.
Of course support didn't contact the local dealer so at point of purhcase they had no idea what I was talking about when I took the bike to them in August to see if the warranty work/part could be done. However, the PoP shop took over the case for me and dealt with the supplier... time goes by until finally last week they contact me to bring the bike in, the replacement part has arrived.
The evening before I drop the bike off I take a ride, 14km climbing and 14 descending, fast AF, brakes dialed in, rims true, bike rides well for what it is. I dropped it off and told them the head light occasionally didn't work and demonstrated that it needing a bit of a bounce to light up.
The local shop fished a new wire through the downtube for the headlight and replaced the headlight switch, both under warranty. The shop also replaced the controller and billed me for it, $130, apparently this part is out of under warranty.
Ok...that sucks and is a lot of money... I pay and take my bike, the motorcycle mechanic was happy to point out the headlight work.
Today I take it for a ride, during pre-flight check I had to install the front wheel, I noted the tires are a bit soft and topped them up, brakes felt a lot stiff and the cable adjusters were spun all the way in at the brake levers.... that's odd, someone adjusted my brakes..... but in pre-flight testing the brakes worked correctly... so... battery full... off I go.... 7km up, not too fast, mostly twist throttle in cruise control.... and the brakes felt great but twice it seemed a bit slow to shut off the drive. (this is what we call foreshadowing)
I was filming my ride on descent, taking it slow, staying under 25mph in the downhills and 18mph in the up hills, I got to the top of the last hill and touched my brakes to shut off the cruise control.... but the motor kept going full tilt.... I grabbed the brakes and applied force, the motor strained against it... I had slowed enough to turn around and headed uphill.. the motor continued to run at full throttle. I pulled my cell phone off the mount so it can be seen, I'm pulling the left (rear) brake lever and the motor is still accelerating. 250w uphill is not much, but still... obvious problem is obvious
I held the power off button for 3 seconds and the motor shut off when all power was off, it was a long 3 sec.
The next issue was not due to the motor... but..... someone adjusted my brakes
with the motor powered off I headed back down the last hill in acoustic mode, and the first pull of brakes the left (rear) brake made a fun snapping sound and pulled all the way to the handlebars, naturally I tightened on the right hand side and that's about the time the right lever (front brake) make the same sound and also compressed all the way to the handlebars and the bike began to accelerate.
I bailed off the bike and managed one hop before gravity got the goods on me, the next hop I landed on my knees and toes and slid like I was on a skate ramp. Nasty gravel rash on the right knee.
I limped down the hill walking the bike, both brakes completely compressed and barely any drag to slow the bike. I noted a loose brake cable on the rear brake cable.
The BSO is back at the shop I purchased it from, I spoke with the owner of the shop and shared this video... I think warranty should have covered the previous controller, this one failed in such a manner I don't know if I'll ever trust this bike again
