rocketman58
- Joined
- Aug 6, 2022
- Messages
- 77
I am thinking of converting from a Bafang geared hub drive to a Bafang BBS02. My geared hub drive uses a KT controller that has 5 PAS settings. Each setting provides a set level of assist up to the maximum speed of the motor.
This is very different from the original Bafang controller that came with the motor. That controller provided a specific amount of assist up to a certain speed then the assist stopped. For example: Level 1 assist stopped at 9mph, Level 2 assist stopped at 12mph, Level 3 assist stopped at 15mph, etc. It was not possible to pedal at 17mph with a lower amount of assist like you might get in levels 1 or 2.
How does the BBS02 provide assist? Is it like the original Bafang controller I had that limits you to a certain speed in each PAS level? Can I program it so there is no speed cut off at any assist level like my current KT controller?
Currently I ride at speeds up to 20mph using assist levels 1 or 2. I do not (yet) need the level os assist that 3 - 5 provide.
One more question: Are there any issues when using the BBS02 with a 20" drive wheel?
