Hi,
I just got a 500w 48v bafang rear hub kit including a varstrom controller https://a.aliexpress.com/_EG6jgCS
and the driving is awful. Acceleration is way too sudden and strong, then the speed decreases by itself and reaccelerates. It's irregular and feels uncontrollable, very unpleasant. It's worse with the throttle, as 70% of it does nothing, and then suddenly it goes to full speed. No steady acceleration, no control, no smoothness. Also, the delay is too long after pedalling before motor starts. And the delays when switching between throttle and pedal sensor are also weird and long and unnatural.
1. Can this controller (9A normal, 18A peak) be programmed? I know the bafang mid drives can with a usb key and an app, but I remember reading that it may not work with hub motors. Is that true?
2. I'm thinking of buying a kt controller (with display) that is programmable to have a steady and smooth control on the motor's behavior both with pedalling and throttle.
Any advice, any info, any feedbacks from experience, anyone in a similar situation??
