Hi
long time lurker, first time poster
I have a BBSHD with 2000+ miles that I recently disassembled to grease the nylon primary gear to cut down on the squeaky noises. When I reassembled I got a 08 error (hall sensor) due to a bad physical connection. I reseated the connector, reassembled and the BBSHD worked fine with the throttle, but I was unable to get Pedal Assist working. I do not see any error messages on the display and have had no issues with prolonged use of the throttle. I contacted the vendor (EM3EV) but haven't heard any reply yet (who even knows if they are actively responding to support). I was wondering if there is any possibility that there was some kind of short that affected the PAS when the hall sensor connection was bad, or if its possible something happened when reassembling as the cranks feel a little different now (i can feel the clutch slip a little when pedalling slowly and backward). I've taken the motor apart for greasing/maintenance before and hadn't had any problems, so kind of stumped on how to test this.
Thanks!
Thanks!
