Belt drives are remarkable when mounted with proper alignment and coupled with a Bafang BBSHD mid drive to Nuvinci 380 IGH. Of course like most builds, it comes with challenges.
83.2 KB
Could you give a build list, specifically the chainwheel / adapter you used? I have a TSDZ2 on mine, cracked the stock plastic chainweel 2nd time out, had to get the aluminium one with a 130BCD adapter.
Unless I misunderstood the text for each of the images in his post, he made his own, by combining the inner part of a lekkie ring with the tooth part of a gates belt sprocket.
I'm looking to do this same conversion but with the 750w bafang mid drive. I see you made your own chain ring. That's really nice but looks challenging.
Would I be able to use the spider chain ring adapter instead?
Did the bbshd motor fit perfectly ? I can't find the bottom bracket specs anywhere for this bike.
Please excuse my ignorance I'm new to converting a bicycle to an ebike but really want to make a belt drive bicycle into a mid drive ebike.
