thisrealhuman
100 µW
- Joined
- Feb 29, 2016
- Messages
- 7
First, the obligatory thank you to everyone in this forum. I've been lurking and learning for probably three years and I wouldn't have made it this far in my build without you, so thanks!
Build Specs:
2x 5s Lipo Zippy Compact 5800mah (used in series, charged in parallel)
120A K-Force Opto ESC
245KV Eflite Power 160
ADS UST Mount 12T/36T
77mm Speed Vent (115mm Tom Shanahan Inc. Powerboard wheels shown at bottom)
GT2B with Badwolf v2 (will be posted when complete)
Castle Creations 20A BEC PRO (dead)
CNC Skateboard LED Riser pads (http://cncskateboards.com/led_skateboard_lights.htm They're spiffy! I'll get some video and full review once my power is back.)
Pelican Micro Cases 1040 and 1060 (http://www.pelican.com/us/en/product/watertight-protector-hard-cases/micro-case/standard/1060/)
Now here's my problem; My xt90 loop key rattles loose and falls out cutting my battery connection, but when moving at speed the motor creates energy that feeds back through my ESC and only has one place to go; into my BEC. I've killed two BECs this month and I'm looking for a better wiring solution. Relocating the loop key will happen too, but that will be a side effect of better wiring.
(I don't understand why some images are showing and others are links)
Here's my wiring diagram:
And the actual wiring (sorry for potato quality):
When I had a non-OPTO ESC (Turnigy AE-100, VERY BAD), the disconnected battery would leave nowhere for the power to go in the event of a disconnect, and the power would loop back into the motor and cause it to lock. With an OPTO, the same is true, but having my BEC connected means the power has a place to go, so the motor won't lock until after I blow the input cap on my (one week old $45) BEC. (mumble, mumble, false economy...)
After my loop fell out, I tried restarting the system and noticed my lights came on and wouldn't shut off using their individual power buttons, and while I was trying to turn them off, my antispark resistor burned up. I assume this was because the input cap on the BEC had already popped and was sending more power than it should have been. My lights run on 4.5v (3 AAA's), so I'm using the CC BEC Pro default power of 5.1V (9A) to power them and my receiver (GT2B). My loop key wasn't in and the board was not moving when all this happened.
I went with the Turnigy K-force because I feel more secure with a DRAG brake. Future builds will use VESCs, but I'm not ready to open that can of worms until the product is a little more polished.
I'm going to get some fuses to put inline near the batteries and just before the BEC. I'm not sure if I trust a simple button and relay, so the loop key will remain king. New enclosures will be fiberglass or carbon fiber once I have all my components and wires figured out. Those wires are sealed to the case with two layers of shrink tube and Shoe Goo. I can use a razor to remove all of it and have already done so three times, everything is temporarily permanent.
So here are my actual questions:
Is there a specific BEC for 10s lipo that I should look into?
Other than adding fuses, is there a way to wire this with an automatic disconnect when the loop is out?
Extra shots:
Build Specs:
Extra shots:
