Geebee
Best 12v 12ah sla battery in Oz and where to buy?
Need some new batts for the moped the current ones are 3 years old and totally worn out, I knew they were tired but todays ride showed just how tired they were.
Does the brand of battery make a lot of difference or should I just go and buy some cheapo jump starter packs?
Another possibility is to go to 18ah DiaMec batteries, it would be a pain fitting them but they would cope with the discharge rate better, worth considering?
Heres the specs on the 18AH batteries:
18.0 Amp Hour 12V Sealed Lead Acid Battery
SLA- Size 181(L) x 76(D) x 167(H)mm- Charge current 1.8A for 10- 14 hours- Discharge current 20hr rate 900mACapacity:- 20hr rate (0.90A) 18.0Ah- 10hr rate (1.72A) 17.2Ah- 5hr rate (3.05A) 15.2Ah- 1hr rate (10.8A) 10.8Ah- Int Resistance: Fully charged (20°C,68°F) 15m Ohm- Max Discharge Current (5 sec):100A- Constant Voltage Charge: Initial charging current < 6.4ACycle:- Voltage 14.40V~15.00V @ 20°C (68°F)- Temp Coefficient: - 30mV/°CStandby:- Voltage 13.5V~13.80V @ 20°C (68°F)- Temp Coefficient: - 20mV/°C- Nuts & Bolts Supplied
The other plus with these is that I get a discount through work and will probally get 3 for $100 au. or so.
