johnnyz
Ok...I have a 28 Cell headway battery pack for my trike. I had a generic bulk charger for it charging to 102 volts at 6 amps. This was sufficent untill suddenly it stopped. I have a race this weekend in Toronto. I need to come up with something fast...
I have another 72 volt charger (pictured). It has 3 blue potentiomiters?...that are adjustable. I think they are for voltage and min and max values. The problem is that the caps are rated for 99 volts (so someone told me). If I change these out then can this be adjusted to 100 volts or so?....thats the first question..
In the mean time I can split the pack for now with 24 cells ( and the 72 volt charger will charge these just fine...its the other 4 that I have to charge..problem is this: My IMAX charger even when charging just one cell on FAST charge reduces the charge to around 1.5 amps and this is TOO low..its gonna take days for these 4 cells...is there some way to up the amperage?....its suppose to be a 5 amp charger..not sure why this is happening. The cells in the 4 cell group are all around 3.29 volts...
Lastly I guess for now I can charge the 24 cells and use a "bulk" charger for the last 4 and charge them seperately but need at least 4-5 amps at 15 volts....cant find anything around here. When this is done then I will probably buy a nice RC charger but need one that will do at least 10 cells at a time BUT at at least 5 amps so it doesnt take forever.
Does anyone have any ideas?
