neptronix said:
as it will put unnecessary wear ( over a long period of time ) on cells that have a strange RI / voltage curve.
I am not disputing that ..if you have experienced it, but can you explain what you mean a bit more..I can't understand quite what you mean.
From what I see with 'Always balance 'On is that it just starts the balancing at a lower voltage level. So it does not wait to bring a highest cell up to terminal voltage before starting to bleed it off. Why would this be an issue.
neptronix said:
I like the slow balance mode because it gets my batteries pretty damn accurate, within 5mV usually.
I can't measure to that accuracy I am afraid. I only have cheapo e-bay meters and one more expensive Sealey one..but all still only 2 digit after teh decimal place.
I do have two cellogs, with two more on order..and they allegedly give 3 digit accuracy, but from my experience of them over the last month, they are not more accurate than the Battery medics..OK they read to 3 places, but swap my two cell logs between the same battery, and they both only give accuracy to within 10 mV.
Really need to build or buy an accurate voltage divider source/network, that we can plug in to these devices, and get an accurate output across 8 10 14 cells some can plug in to a iCharger/Cel log and calibrate to exact voltage of our source.
I am going to post a thread on that. Will come back and edit this thread with the link once done
Done
http://endless-sphere.com/forums/viewtopic.php?f=14&t=37219
