Best way to charge and use batteries?
Lifepo4 batteries can be stored fully charged. The BMS will slowly drain hem, so if your battery has to be stored a long time you should charge it once a month.
if you store it for long periods such as over the winter, then you should disconnect the sense wire bundle from the BMS. leave it 60-70% charged, not fully charged. but you have to remove the sense wire cable.
