eTouringOldie
100 µW
Much as I’m excited about the potential of SS batteries, I’m too old to put things off until (say) 2030.
I’m planning a touring e-bike trailer w/ a big capacity battery — say 3-4 kWh+. It needs to power a 52V Bafang M620 motor (stock controller), so 40+ amp discharge.
Requirements:
Faster (relative of course) charging — 500W / 10 amp+ if possible
Better cold weather performance
My initial idea is something like 20 EVE LF50Fs (50Ah), which would have a nominal voltage of 64V, so a bit high, but 3.2 kWh. 18 would do 57.6V, so better? Only 2.88 kWh. Each module weighs ~1kg, so 18 or 20 kg + bus + bms + case. Around 50 lbs for the 18 cell config, or 55 for 20.
Also, there are 55Ah Liitokalas which are actually spec’d as slightly lighter, so 18 of those would get me the 3 kWh+.
The point is to be able to do some serious long-distance, off-road touring — trailer will also carry a canteen (10L?) and I’m considering a hub drive on the trailer for regen braking on downhills (for the braking power, not the regen, maybe also for help up steep inclines).
I know I’m paying a weight penalty for LiFePo4 vs Li-ion, but fast(er) charging and cold performance are pushing me that direction. Also, I’m hoping I won’t get shut out of places to ride because of Li-ion fire paranoia.
So, my questions are:
Does this even make sense?
Are the EVEs better than the Liitokalas? Stronger, heavier cases? More reliable? More cycles?
Am I better off w/ 64v nominal, or 57.6v for my 52V motor? Is it possible to have a 19 cell config (so 60.8V)?
Is there a better Li-ion story I’m not understanding?
Is there an NMC story that doesn’t end up being $2k+ just for the cells?
Should I forget the rear motor and just add brakes on the trailer — might be carrying a lot of unused weight most of the time? (OK, that’s not an e-question).
Bonus for bms recommendations or pointers to battery builders who mights do this job
Thanks
Requirements:
Thanks
