NeilP
1 GW
Just got hold of some lead acid single cell units from a scrapped aircraft tug.
36 of them...2 volt each
XWBF17's
OK,so they are old...2006. so they are unlikely to have full capacity ..but I wondered what their original capacity should be.
http://www.espexbatteries.co.uk/brochures/Traction%202V%20DIN%20Standard%20-%20Normal%20Capacity.pdf
http://www.ceilbatterysystems.com/userfiles/file/CeilNXNORMALspecsheet_100923.pdf
The table linked to above say 80Ah Positive plate capacity, but the table entry for "Ah @C5 at 30 Deg C" shows 640 Ah ????what gives here?
I firstly picked them up for two reasons..scrap ;lead value and I can use the acid as a weedkiller to knock back ivy on the farm
But then I thought ..if there is enough life in these cells, then I can use them on my solar system in our camping / party / relaxation meadow, I have a little shed/ log cabin plus 200 watt of solar panel..but only maybe 40Ah of battery capacity.
I could rig up 12 of these as 6s2p and give me a waxing amount of capacity..even if they are only 50% of original
Or am I better selling them off for scrap and just buying new lead acid cells designed for solar system ?
XWBF17's
