Marsupilami said:Anyone here recently bought something from the site www.lithiumbatterypcb.com, almost 1 month ago i bought a bms, no reply sofar, order is still processing
Marco
Hertzelz said:Hey Guys,
I'm about to get a 20s1p LG CHEM M2.1 cells (total 72v60ah, 180A const current),
So I need a 200A BMS,
Should I go for the ANT bms?
or https://www.aliexpress.com/item/32804527877.html LLT one (but without bluetooth)?
There is an LLT 200A with bluetooth on their website https://www.lithiumbatterypcb.com/p...cle-pcb-with-200a-constant-discharge-current/ - but they're not responsive on emails or skype, so I prefer to avoid buying from the site directly.
I've heard mixed reviews on the ANT's as sometime it 'forgets' cell groups,
but the LLT is without Bluetooth, but looks far more 'robust' in terms of build quality to my eyes...
What would you choose?
The controller will be ASI BAC4000.
*I've searched this thread and didn't find any conclusive answer, is the LLT reliable enough to buy without bluetooth abilities?
Nitpicky I knowst35326 said:According to my CA the most Ive drawn around 160 amps daily (10-12kW)
Miwer said:Marsupilami said:Anyone here recently bought something from the site www.lithiumbatterypcb.com, almost 1 month ago i bought a bms, no reply sofar, order is still processing
Marco
Hi Marco,
I am wondering the same. I also ordered a BMS from lithiumbatterypcb.com a month ago, and my order is also still "Processing". I've tried to e-mail them multiple times, no answer. I even created a skype account, and sent them messages there, no response. Even tried to call them, no pickup. If I don't hear from them soon, I will make a complaint with paypal to get my money back.
Fionn said:What version Android are you running JC?
Xiaoxiang is usually a sure bet but you need the right version for your OS.
If you've the wrong one it usually behaves as you desbribe.
Agree.Fionn said:Quite simply you just need the correct version of the app for your OS.
I'm running android 6.0 and v2.1.1022 of Xiaoxiang & it works perfectly.
Newer versions of Xiaoxiang install, look good & everything on this OS but won't connect.
john61ct said:No you need to charge at 4.05V at a minimum to get any decent range.
4.10 or 4.15 are still conducive to longevity.
3.5V is below where you should be stopping in effect empty.
Technically it is the charger that lowers the current.SilverLine said:Yes.. but i´m only talking theoretical here.... Is it right that my CC/Cv charger, lower the charge amp when close to end voltage ?? (4.20v pr. cell) Or is it the BMS that does it...
Just checked mine. Seems ok. Only needs one tap. It does take a second or so to activate though.Fionn said:One minor annoyance, does anyone know the trick to enable the lock/unlock feature where the speed display normally shows on thr dashboard screen?
It seems to require a random number of taps.
That is never true for mainstream chargers unless they allow the **user** to adjust current up and down. But only very very rare specialized charge sources of any kind do any "live" adjustment of current during a given charge cycle. Sometimes as a thermal protection measure. . .serious_sam said:Technically it is the charger that lowers the current.
FFS, you're starting an argument over semantics.john61ct said:So I have no idea what your statement above is referring to.
