cycborg
flippy said:the FET on a balance port fried itself. it happens on crappy bms.
But could this result in the failure cascading through 5 groups?
cycborg said:But could this result in the failure cascading through 5 groups?
Do you mean number 5? It's groups 1-5 that failed. Regardless, what's the mechanism that causes this cascade?flippy said:...the number 7 FET is blown up.
Hi i have the same problem with the pc sw. cant connect i have the ant bms got it from aliexpressInwo said:14s bt cell count.png
So... are you writing your own software?plateau said:I have replaced the µC
cycborg said:So... are you writing your own software?plateau said:I have replaced the µC
john61ct said:if it ain't broke, don't fix it
flippy said:john61ct said:if it ain't broke, don't fix it
if it aint broke: mess with it until it is.![]()
flippy said:you need to disconnect ALL users before callibarating the shunt. ANY current flow will mess up the reading.
plateau said:Hi, people, how are you doing?
I'm trying to repair my bluetooth BMS but I don't know which component is that marked with this blue arrow. I know it's a diode but I don't know if it is a rectifier, schottky or a zener. It fried after the 10R resistor (white arrow) has blown.
Further, I have replaced the µC (ATMEGA328P) and the 10R (white arrow).
Does anybody can help me?
