oldhaq
LOL
Not quite sure what you're asking exactly, my phase length is about 15 metres each, so I ran 8 straight lengths of 15.5m, twisted the ends at one end together, then spooled all 8 lengths in parallel onto a large bucket turned upside down, so I had effectively a 15.5m length of wire with 8 cores. I then wound all of phase C first, then repeated the process for B then A phases. So I spose I used 15.5x8x3=372 metres, that's a fair whack of copper and it definitely feels like a lot as you slowly make you way tooth after tooth. If it does burn up I'll cop it and redo it with thinner wire or wind it 6x10, as it was a marathon effort if I do say so myself. I just thought I'd take it to the extreme at least this once, even if it is my first wind.
Got a motor/hall/controller tester off ebay a couple of month or so ago, so this was the perfect time to try it out..
[youtube]UwvCoQSu17Q[/youtube]
You hook it up to the hall and phase wires, so it must measure the bemf from the phases i expect, and prob the same concept as lyens tester i imagine. Runs on a 9v battery. So looks like all systems are GO!
$21 delivered at http://www.ebay.com.au/itm/261043137276?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
I also got a hua tong controller with 4410 fets from them, was $35 but they've now put the price up to around $55 like all the other ebay sellers.
