redorblack
- Joined
- Sep 26, 2009
- Messages
- 142
I see a lot of people are using the Signalab V2.5 BMS. apparently sourcing them from Ping. I don't see him listing them on his website separately... are some of you buying just them to replace the Headway BMS setup or scavenging them from Ping battery packs?
The thing I did see on Ping website... an option to upgrade to a 9A charger with the 48V 30ah pack. Anyone get just one of those? Would it work ok with a Headway 16S pack? I'd be under 1C with my 48V10Ah Headway pack... the idea of tripling the charge rate from the 3A charger I got along with my Headway pack (at least for a good portion of the charge) has a lot of appeal.
Is there a downside to running a 9A charger... maybe not balancing the cells as well? I'm thinking a cell would hit HVC and the pack wouldn't get a chance to balance out through the stock BMS? Would the Ping not fill the Headway cells due to a bit lower charge voltage?
I have been a bit concerned about my Headway pack having 2 cells a bit lower than the rest, while 14 cells are 3.6-3.7v when the charge cycle with the matched 3A charger, one was 3.58v and one stays under 3.4v. I found a wall wart 500ma 4.5v power supply and cut the charge plug off it and wired it to the low cells and plugged it in while monitoring voltages. I brought the 2 cells up to about 4v and let them rest, (only took a couple of minutes) then hit them with some juice again when they dropped back down under 3.65v. I just checked current and the "500ma" power supply was putting 860ma out when I applied it and went down to about 600ma after a couple of minutes. I disconnected it and switched back to voltage and the cell is up to 4.02v. Am I hurting the cell or just getting it closer to topping off? It dropped back to 3.65 in the amount of time it took me to walk back here to the computer and write those last two sentences about checking current and voltage...
