Hi All,
I recently purchased the following from BMS BAttery:
12 MOSFETS Controller 48V
Bafang 350W 48V BPM Permanent Magnet Brushless High Speed Motor
EV-4810LF-05 48V/10Ah LiFePO4 Pack
Throttle.
Does anyone have any experience with these products? They came with a cable to connect the battery to the controller. Everything plugs together well. I'm running with just those four items connected, no hall sensors.
I am having some problems and would appreciate some help. Full details are below. If you can suggest anything that would be helpful, I am all ears!
I have the motor in a wheel and hooked up the battery and controller. I turned the key on the battery, turned the throttle and I get nothing. After fiddling for a bit I finally got the motor to spin but when I turned it off and on again, nothing happened again.
I initially thought this was to do with sensorless motor, so I spun the wheel to see if that would work. It didn't.
Eventually I figured out that I could get it to work consistently if I had the key on the battery "on" and the hot plugged the battery to the controller. Motor spins no worries. So this appears to be either the controller doing something to the battery to stop it working or vice versa.
The controller and battery have three wires for power: Gnd, +V and power key on/off lock. http://www.ecitypower.com/pdf/912Mosfet.pdf
I checked the voltage on the battery when I turned the key without the controller and it gives me 53V. Pretty normal.
I checked it with the controller and it goes up to about 20V then down to ~11V within a second.
When I hot plug the battery, the controller gets 53V and it works fine.
It is as if the controller is stopping the battery from delivering what it should. Maybe it is that key on/off wire? So tonight I disconnected that wire to see what happens. The battery got its 53V but it didn't do anything. So I think it needs the wire!
Throttle.
