Overclocker
i haven't seen this done before so i'm just putting this out there...
this is a greentime BMS. the "bleeding" resistors do get quite hot which would heat up the cells directly below. so i provided a thermal path to the outside case w/ some aluminum and a thermal pad
then it's insulated from the batteries with polyethylene foam
