Bofeili/EC Mobility display
Stianaj
New here
Bergen
Hi guys
I have a Serious Mt. Cataract from Bikester, with a BFLT210 motor.
It has some issues. The display works sometimes, but only for a while. Then it's all garbled and then it goes blank. The motor still gives assistance, and if the lights were on they are still on.
I believe I need a new display, and it appears to be the SW102.
My questions:
1. Do you agree with me that it probably is the display?
2. Which version of the SW102 should I buy? I have found several, but they all appear to be for Bafang motors.
Thanks!
Hi Stianaj
This display will work. The center pin is not in use, so don't worry about the plug only having 5 pins.
It can be programmed with the Bafang programming tool.
Hi! You're the first (and only) other person I found that has this motor beside myself. I've just restored my bike that has a bflt210 in it. It had a broken computer. I tried several and got it working with the eggrider v2.0 (and lots of testing!).
Did you ever get it to work?
I was a little dissapointed with the power it outputs. Would you consider yours a powerful motor? Its my first eBike so I cant compare it.
Cheers!
