I just installed on my Pedicab the Golden 901 750w Pro Kit (http://www.goldenmotorusa.com/index.php?pg=hub) powered by a single Golden 36 volt, 16AH Lithium battery ( http://www.goldenmotorusa.com/index.php?pg=batt ).
Overall, I am happy with the system. The speed is more than adequate but I could use a little more power on some of the hills According to Golden, going to their 48 volt Lithium battery would give me 20% more power in the hills. I could also use a little more range.
Because of this I have ordered their 48 volt, 12AH Lithium battery.
Assuming the 20% increase in power from the 48 volt system, my thought was to hook up the two batteries (36 and 48 volt) with a switch accessible while riding. The switch would perform two functions. First, if I ran out of juice, I would simply switch to the other battery on the fly as opposed to having to stop and change batteries. Second, I could use the 36 volt battery most of the time and then switch over to the 48 volt when I encounter a steeper hill. Then swtich back to the 36 volt. Kind of like a "boost" switch. I'm very new to this so I just have the concept but need help in the "how-to" department.
(1) First, is such a system feasible using these two batteries?
(2) Is there a "plug and play" switch like this already on the market that I could hook up easily? If not, exactly what do I do? The manufacturer mentioned I needed an isolator if I was switching between the 36 and 48 volt batteries. Is this part of the switch?
(3) Currently, the 48 volt battery is not available so I may temporarily use a second 36 Volt Lithium battery for just added range. Would I use the same switch or could I use a simpler switch (without isolation) for this setup?
(4) As an alternative to "3" above, could I just hook the two 36 volt, 16AH Lithium batteries in parallel and forgo the switch? The manufacturer said it wasn't a good idea but didn't seem to have a reason why.
(5) As an alternative to the original idea (switching between a 36 volt and 48 volt) could I use a 12 volt Lithium Battery instead of the 48 Volt, then hook it up to the 36 volt in a series arrangement with a switch. That way I could use the 36 volt most of the time and switch to 48 volt power on-the-fly only when I needed it? If this idea was feasible I would probably end up with two 36 volt, 16AH Lithium batteries and a single 12 volt battery.
Thanks for any help.
Richard
Richard
