Brain power 48v 1000w controller hell
MajicRider
So I can have a green power 48 volt thousand watt controller that I'm seriously having issue with, while I've managed to sparse out the wiring for the Hall sensor wiring I cannot for the life of me figure out the 5 wire for the LCD (LCD 3) display.
HELP!
I am down to the last 2 wires yellow and green from the display ( input and send days wires), photo shows what's left.
The controller you posted the wiring of in the first post does not have any way to connect it to an LCD. So you cannot use it with one, unless it has pads for one on the circuit board inside that are simply not wired up. In that case, you'd have to open it up to add those wires, but even then, it may not be programmed to function with one.
Additionally, LCDs are not universal between controllers.
You would need to get the same controller brand as LCD brand; for instance LiShui (LS) has their own LCD series, and the KunTeng (KT) has their own series of LCDs; Bafang has their own series, etc. Even within a brand they are not all compatible with each other.
