fmpwizard
10 µW
- Joined
- Sep 15, 2022
- Messages
- 6
Hi,
I have a Vespa imitation electric scooter that came with a 2000w 60v motor and ordered an upgraded controller and motor (along with the lights, throttle, and battery) to be 72V 4000w
Almost everything works well, but when:
1. I turn the scooter on.
2. I see the initial P on the display, so I press the front brake to release the P mode and go into drive.
3. I accelerate (it's on the center stand, the rear wheel is not touching the ground at this point).
4. I let go of the throttle and wait until the wheel is almost stopped, but it is still spinning.
5. I press the front brake (not the rear brake).
6. The wheel spins in the opposite direction, it doesn't keep accelerating in reverse, it is as if it bounces in the other direction.
The brake light comes up when I press the brake.
I tried disconnecting the two "brake lever" cables and follow the same steps, the spinning backwards doesn't happen, but the brake light doesn't come on either.
From the controller harness, I have two pairs of "brake lever" connectors. And each of them seem to behave differently.
One of them does what I described earlier.
The other, on step 6, stops the wheel in place, as if it is an electronic brake.
I uploaded 3 videos showing what I see, I hope someone here can help me so that pressing the brake just turns the brake light on, disables the throttle but doesn't stop the wheel nor does it send it to spin backwards.
Wheel spinning backwards after I press the brake:
Here I use a jumper cable
Here you see how one of the brake connectors "stops" the wheel, instead of sending it to spin in the opposite direction
Thank you!
Thank you!
